Composition setup variants
You can create a setup.toml file in your composition. It allows you to specify
buildâtime options and variant parameters at runtime.
Note
setup.tomlmust be referenced in yourflake.nixfor this mechanism to work.outputs = { self, nixpkgs, nxc }: { packages = forAllSystems (system: nxc.lib.compose { inherit nixpkgs system; setup = ./setup.toml; composition = ./composition.nix; })};
What you can do with this
You can create profiles for your compositions & configure them with various parameters that can be used within your composition;
Tip
You can initialize the
setupcomposition template by running:nxc init -t setup
Global options
[options]
nix-flags = "--impure"
composition-file = "testing.nix"
composition-flavour = "testing::vm"
flavour = "vm"
kernel-params = "intel_pstate=disable"
These values are used as defaults for the nxc build command. The arguments you
specify when running the command always take precedence over this file.
Parameters
You can define arbitrary parameters under a params table. They are made
available to your Nix expressions in composition via the setup object.
[params]
a = "hello"
b = 74
environment.variables.A = setup.params.a; # Evaluates to "hello"
environment.variables.B = builtins.toString (setup.params.b + 1); # Evaluates to "75"
Tip
You can temporarily override them when running the command by using the
--setup-paramflag (i.e.--setup-param "a=world")You can repeat this argument to add some more.
Variants
A variant is a named section that can provide its own [options] and
[params].
[dev]
[dev.params]
a = "devâvalue"
b = 74
[dev.options]
composition-file = "dev.nix"
Select a variant with --setup:
nxc build --setup dev
The selected variant in this example will then be stored in the file under:
[project]
selected = "dev"
Example
Given the following setup.toml:
[project]
[params]
a = "hello world"
b = 10
[options]
[dev.options]
nix-flags = "--impure -L debug"
Running
will build using the dev variant options, while
nxc build --setup-param "a=override"
will override the a parameter with the value override.
