Import Flakes
If you want to use packages, modules, or libraries form another Nix Flake, you can make it available in your composition using an overlay.
In order to add this overlay, you have to edit the flake.nix file and add your
flake as input. For example:
inputs = {
myFlake.url = "github:myTeam/myFlake";
Here is how you can add an extra package using an overlay or add a NixOS module
using the extraConfigurations parameter:
outputs = { self, nixpkgs, nxc, myFlake }:
let
system = "x86_64-linux";
in
packages.${system} = nxc.lib.compose {
inherit nixpkgs system;
# Use this to make a NixOS module available
extraConfigurations = [ myFlake.nixosModules.myModule ];
# Use this to make a Nix package available
overlays = [
(self: super: {
myTool = myFlake.packages.${system}.myTool;
setup = ./setup.toml;
compositions = ./composition.nix;
Tip
For more details on overlays, checkout the Nixpkgs documentation on Overlays
You can now use your package or your module in your composition just like the
ones present in nixpkgs, for example:
{ pkgs }:
roles = {
node1 = {
services.myService.enabled = true;
node2 = {
environment.systemPackages = with pkgs; [ pkgs.myTool ];
