tuto on pythoneri insert script bash …
Here we complete the quick start guide that was focused on the CLI, we will go further in detail with how to write the composition file, how to import personal software and the different files of a NixOSCompose project.
~ Here we will go through a complete workflow with the local test deployment with docker and a Grid5000 deployment of a Nginx server and a test client.
- initialization
- review of the files
- launch/test
- Edit the composition
- add a benchmark tool
- launch/test
- add a custom script ?
Initialization
First let’s create a folder for our project locally, we are creating it with the template mechanism of Nix flakes. The template that we are importing is a client/server architecture, the server hosts a Nginx webserver.
nix flake new webserver -t nxc#webserver
Tip
To avoid writing the full path to the NixOSCompose flake we are using the Nix registries.
nix registry add nxc git+https://gitlab.inria.fr/nixos-compose/nixos-compose.git
If we inspect the content of our new created folder we obtain this.
$ tree webserver
webserver/
├── composition.nix
├── flake.nix
└── nxc.json
0 directories, 3 files
Description of the files
flake.nix
A file that is key in the reproducibility of project. It defines all the dependencies of a project and what it is able to provide as outputs You can learn a bit onto how a flake file works here.
This file manages the dependencies and the outputs of a project. It has multiple fields :
- description
- inputs
- outputs
The description is a string that describes the flake.
The inputs is a set defining
description = "nixos-compose - basic webserver setup";
inputs = {
nixpkgs.url = "github:NixOS/nixpkgs/nixpkgs-unstable";
nxc.url = "git+https://gitlab.inria.fr/nixos-compose/nixos-compose.git";
outputs = { self, nixpkgs, nxc }:
let
system = "x86_64-linux";
in {
packages.${system} = nxc.lib.compose {
inherit nixpkgs system;
composition = ./composition.nix;
defaultPackage.${system} =
self.packages.${system}."composition::vm";
devShell.${system} = nxc.devShells.${system}.nxcShellLite;
composition.nix{ pkgs, ... }: { nodes = { server = { pkgs, ... }: { services.nginx = { enable = true; # a minimal site with one page virtualHosts.default = { root = pkgs.runCommand "testdir" { } '' mkdir "$out" echo hello world > "$out/index.html" ''; }; }; networking.firewall.enable = false; }; client = { ... }: { }; }; testScript = '' server.wait_for_unit("nginx.service") client.wait_for_unit("network.target") assert "hello world" in client.succeed("curl -sSf http://server/") ''; }nxc.json{ "composition": "composition.nix", "default_flavour": "vm" }
