The intent of this guide is to go through the different commands made available
by nxc. We will depict the workflow while you are setting up your environments
or running an experiment. We are not yet going in detail into the content of a
composition neither how to write it.
Local usage
It is convenient to work locally during the development phase or during the configuration of the software environment, as it allows for fast development cycles. NixOSCompose allows to quickly iterate with docker containers or VMs, and it avoids using testbed platforms during early testing phases.
Later, when our composition is ready, we will deploy it to Grid5000.
Initialization of a project
There are some templates (using the template mechanism of Nix flakes) that
provide the boilerplate to start a project. You can do this either with a
locally available NixOSCompose or with the nix flake command. It will copy
all necessary files. You can use these commands on a new folder or for your
existing project folder.
For the following, we are using the basic template. It is a composition that
describes an evironment composed of one node called foo that contains nothing.
Nix flake’s template
To avoid writting the full path to the NixOSCompose flake we are using the Nix registries.
nix registry add nxc git+https://gitlab.inria.fr/nixos-compose/nixos-compose.gitSo now in any Nix flake related command writting
nxc#will be equivalent togit+https://gitlab.inria.fr/nixos-compose/nixos-compose.git#.# initialize current folder nix flake init -t nxc#basic # or initialize projectFolder nix flake new projectFolder -t nxc#basic -
local NixOSCompose
Using your locally installed NixOSCompose the commands are the following.
cd nixos-compose nix develop .#nxcShellLite cd path/to/projectFolder nxc init -t basicYou can then quit the
nix-shellprovided by the commandnix developwithCtrl-d.
At the end you end up with this:
$ tree projectFolder
projectFolder
├── composition.nix
├── flake.nix
└── nxc.json
0 directories, 3 files
These 3 files are the minimum requiered by NixOSCompose.
flake.nixis the entry point for a Nix project, it defines all the dependencies and exposes differents outputs, likedevShellsorpackages.composition.nixwhere the configuration of the roles needed by your experiment is described.nxc.jsondefines a few default variables for NixOSCompose.
All those files need to be tracked by Git. Nix flakes even require it to work properly.
git init && git add *
If your project is already using git you just need to add those files.
git add flake.nix composition.nix nxc.json
Overview of composition.nix
Nodes are listed under the field nodes and we can see that we have one node
called foo.
{ pkgs, ... }: {
nodes = {
foo = { pkgs, ... }:
# add needed package
# environment.systemPackages = with pkgs; [ socat ];
testScript = ''
foo.succeed("true")
Local development and usage
First enter the nxc shell. Here we choose nxcShell because it provides all
necessary dependencies to run the composition locally (e.g. docker-compose).
Note
The first call to
nix developcan take quite some time because it will fetch and/or build all depedencies for thenxcshell. Later calls to this command would be faster because everything will already be present in the Nix store (on condition that the flake’s inputs did not change).
Building
The composition can then be built. The command below will evaluate the
composition file then build the necessary artifacts for a local deployment using
docker containers. The files generated at build time for the different flavours
are put in a new build folder. As we are building the docker flavour, it
hosts the docker-compose file for our composition.
nxc build -f docker
Tip
If there is an error in the nix code this is when it would show up.
Local deployment
1. Start
The local deployment is done thanks to the command below. The option -f docker
says that we explicitly want to deploy the composition with the docker flavour.
This option is optional. If called without it, the command would choose the most
recently built flavour.
nxc start -f docker
You can check that the corresponding container has been launched.
$ docker ps --format '{{.Names}}'
docker_compose_foo_1
Note
The
buildfolder does not need to be tracked by git.
2. Interact
You can connect to the node with
nxc connect foo
which will open a shell in the container foo.
3. Stop
Lastly the virtualized environment can be stopped with the following command. It stops the container previously launched.
nxc stop
Edition and test loop
The three steps above plus the editing of the composition create a convenient “Edit - Test” loop. It allows to quickly iterate on the set up of the environments. At some point the configurations converge to something satisfactory and physicial deployment is the next step.
Physical deployment on Grid5000
At first you need to import your project to your home folder on Grid5000 with your prefered method (rsync, git, …).
Building on Grid5000
This phase requires the reservation of a node in interactive mode with
oarsub -I. Once you have access to the node you need to activate Nix with
the script nix-user-chroot.sh (see
grid5000 install)
./nix-user-chroot.sh
Enter the nix-shell that provides the nxc command.
cd path/to/project
You can now to build the g5k-ramdisk flavour.
nxc build -f g5k-ramdisk
Since the Nix store is shared between the frontend and the build node, all
created artifacts will then be available from the frontend for the deployment.
Everything will stay accessible from the build folder.
Once the building is done you can release the Grid5000 ressource.
Deployment
The first step is to claim the ressources needed by the project, here only 1 node.
enter virtual env that contains nxc
cd path/to/nixos-compose
source "$( poetry env list --full-path | grep nixos-compose | grep py3.12 | cut -d' ' -f1 )/bin/activate"
Ressource reservation
The reservation through the command line needs the command below, it requests
one node for 30 minutes. At the same time it lists the machines in the stdout
file associated to the reservation ( OAR.<oar_job_id>.sdtout ) and defines the
$OAR_JOB_ID environment variable. This information are needed for the next
step.
cd path/to/project
export $(oarsub -l nodes=1,walltime=0:30 "$(nxc helper g5k_script) 30m" | grep OAR_JOB_ID)
Note
The command above asks OAR for some ressources, then execute a script that sends the user public key to the nodes.
export $(oarsub -l nodes=<NODES>,walltime=<TIME1> "$(nxc helper g5k_script) <TIME2>" | grep OAR_JOB_ID)
- NODES : number of nodes needed for the experiment.
- TIME1 : duration of the reservation with
h:minute:secondsyntax (see Grid5000 wiki)- TIME2 : duration of the
sleepcommand sended to the nodes, usualy same lenght as the reservation duration. Syntax available in coreutils documentation
Once the resources are available the OAR.$OAR_JOB_ID.stdout file is created.
$ cat OAR.$OAR_JOB_ID.stdout
dahu-7.grenoble.grid5000.fr
Actual deployment
At this step we have ressources available and the composition has been built in
the desired flavour, g5k-ramdisk. We can now launch the deployment. The
command is similar to a local virtualized deployment exept for the option -m
that requiered a file that list all remote machines covered by our deployment.
If you used the command seen at the previous step the list of machine is in the
OAR.$OAR_JOB_ID.stdout file.
nxc start -f g5k-ramdisk -m OAR.$OAR_JOB_ID.stdout
Interact
Similarly than with docker run locally, the command below will open a shell in
the foo node.
nxc connect foo
Release of ressources
Once you finished with the node you can release the ressources.
oardel $OAR_JOB_ID
