Keyboard shortcuts
Press ← or → to navigate between chapters
Press S or / to search in the book
Press ? to show this help
Press Esc to hide this help
Multi-composition
Sometimes you have two or more compositions that have a lot in common. For example, you want to test a tool with different integration, or run performance tests on multiple similar tools, etc…
To do so, NixOSCompose provides a simple mechanism that allows you to create a multi-composition.
Example
Here is a simple example of a composition.nix file:
  oar = import ./oar.nix;
  slurm = import ./slurm.nix;
Each *.nix file being a composition file itself. For example, the oar.nix might look like:
{ pkgs, ... }: {
  roles =
    let
      commonConfig = import ./common_config.nix { inherit pkgs; };
    in
      server = { ... }: {
        imports = [ commonConfig oarConfig ];
        services.oar.server.enable = true;
        services.oar.dbserver.enable = true;
      node = { ... }: {
        services.oar.node.enable = true;
  rolesDistribution = { node = 2; };
This compositions can be built and started with the VM flavour using the -C or --composition-flavour option:
nxc build -C oar::vm
nxc start -C oar::vm
Tip
NixOSCompose will build all compositions when -C parameter is not provided in the build phase. Although, the -C parameter is still required for starting.
Step-by-step how-to create your first multi-composition
First, initialize the template wherever you feel like it belongs:
cd somewhere
nxc init -t multi-compositions
You can then edit your compositions (you can learn more over here).
Build everything:
nxc build
Then finally run it:
nxc start -C foo::vm
