g5k-ramdisk
and g5k-nfs-store
Reserve the nodes
export $(oarsub -l nodes=1,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
Deploy
nxc start -m machines
where machine
is the file containing all the addresses of the nodes to use.
Here is an example:
dahu-1
dahu-2
dahu-4
You can generate this machines file with the command:
oarstat -u -J | jq --raw-output 'to_entries | .[0].value.assigned_network_address | .[]' > machines
