Build your first composition
You can build the composition with the nxc build command
It takes as argument a target platform, that we call flavour.
nxc build -f <FLAVOUR>
There are different flavours that NixOS Compose can build:
docker: Generates a docker compose configuration -
nspawn: Experimental Generates light-weight container runnable with systemd-nspawn. -
vm: Generates Qemu Virtual Machines -
g5k-nfs-store: Generates Kernel images and initrd without a packed/nix/store, but mounts the store of the frontend. Also deployed withkexec -
g5k-image: Generates full system image
In this tutorial we will focus only on g5k-nfs-store, and g5k-image if you have time.
For example, let us build the composition with the g5k-nfs-store flavour:
nxc build -f g5k-nfs-store
