Creating a service
Currently, the creation of the GlusterFS volume is manual, but we would like to do it automatically at boot time.
To do this, we will create a systemd service and use it in the composition.
In NixOS, a service (or module) is composed of two parts: the interface and the implementation.
In the previous sections, you already interacted with services ! For example:
services.glusterfs.enable = true;
Creating the module
Let's create a new file to store the content of the service:
# my-module.nix
{ config, lib, pkgs, ... }:
with lib;
let
cfg = config.services.my-glusterfs;
in
# Interface
options = {
services.my-glusterfs = {
enable = mkEnableOption "My glusterfs";
package = mkOption {
type = types.package;
default = pkgs.glusterfs;
volumePath = mkOption {
type = types.str;
default = "/srv";
volumeName = mkOption {
type = types.str;
default = "gv0";
# Implementation
config = mkIf (cfg.enable) {
systemd.services.my-glusterfs = {
description = "My GlusterFS module";
wantedBy = [ "multi-user.target" ];
after = [ "glusterd.service" "glustereventsd.service" ];
serviceConfig.Type = "oneshot";
script =
if [ ! $(${cfg.package}/bin/gluster volume list | grep ${cfg.volumeName}) ]
then
mkdir -p ${cfg.volumePath}/${cfg.volumeName}
${cfg.package}/bin/gluster volume create ${cfg.volumeName} server:${cfg.volumePath}/${cfg.volumeName}
${cfg.package}/bin/gluster volume start ${cfg.volumeName}
fi
Ok, let's decypher what all of this means.
we created a service called
my-glusterfs -
the services has 4 options:
enable: to enable or not the service -
package: the Nix package containing theglusterfsbinaries -
volumePath: the path on the server where the volume will be created -
volumeName: the name of the volume
Then, in the implementation part, we explicit:
that this service is wanted by the
multi-userservice -
that this service needs to be executed after that the GlusterFS deamon has been started (
glusterd.serviceandglustereventsd.service) -
that this service must only be ran once (
oneshot) -
and finally, the commands to run. Here the commands are the same as the ones seen in the previous section, but we are using the configuration of the service:
cfg.VolumePath,cfg.VolumeName.
Call this service
Let's now use this service in the composition.
server = { pkgs, ... }: {
# We import the definition of the service
imports = [ ./my-module.nix ];
enable = true; # We activate our service
volumePath = "/srv"; # We define where the volume will be
volumeName = "gv0"; # and the name of the volume
networking.firewall.enable = false;
fileSystems = {
"/srv" = {
device = "/dev/disk/by-partlabel/KDPL_TMP_disk0";
fsType = "ext4";
environment.systemPackages = with pkgs; [ htop ];
Now, everything the server boots, it will create the volume and start it so that it should be available for the nodes to mount.
Building
nxc build -f g5k-nfs-store
Deploying
Reserving the resources
This time two nodes.
export $(oarsub --project lab-2025-compas-nxc -l nodes=2,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
Starting the nodes
nxc start -m OAR.$OAR_JOB_ID.stdout -W
Connect
nxc connect
Re-mount the volumes on the node
On the node:
systemctl restart data.mount
You can now use the volume from the node !
