Run the benchmark in the environment
As done previously, we have to go through the nxc build and nxc start phases.
Once the environment deployed, we connect with nxc connect
We can now try to run the benchmark.
mpirun -np 4 MADbench2.x 640 8 1 8 8 1 1
Unfortunalety this will fail for several reasons:
we are running as root
there are not enough slots to start 4 processes
As we are setting up the environment for now, we can disable these warnings by adding some flags:
mpirun --allow-run-as-root --oversubscribe -np 4 MADbench2.x 640 8 1 8 8 1 1
