Deploying the g5k-image flavour
Reserve the nodes
Let us deploy this composition on 1 physical machine
export $(oarsub --project lab-2025-compas-nxc -t deploy -l nodes=1,walltime=1:0:0 "$(nxc helper g5k_script)
1h" | grep OAR_JOB_ID)
You can use oarstat -u to check the status of the reservation
Deploy
nxc start -m OAR.$OAR_JOB_ID.stdout -W
Release the node
oardel $OAR_JOB_ID
