Making MADbench2 available
Option 1: You have a flake reprository with MADbench2 packaged
In the flake.nix file, add your reprository as an input:
description = "nixos-compose - basic setup";
inputs = {
nixpkgs.url = "github:NixOS/nixpkgs/21.05";
nxc.url = "git+https://gitlab.inria.fr/nixos-compose/nixos-compose.git";
mypkgs.url = "URL TO YOUR PKGS";
outputs = { self, nixpkgs, nxc, mypkgs }:
Then create an overlay with adding the benchmark:
let
system = "x86_64-linux";
myOverlay = final: prev:
mb2 = mypkgs.packages.${system}.MADbench2;
in {
packages.${system} = nxc.lib.compose {
inherit nixpkgs system;
overlays = [ myOverlay ];
composition = ./composition.nix;
# setup = ./setup.toml;
Option 2: You have a local file packaging MADbench2
In this case, you do not have to add another input, and you can simply call the Nix file packaging MADbench2 (MADbench2.nix in the example below).
Similarly, we create an overlay with the package to add.
inputs = {
nixpkgs.url = "github:NixOS/nixpkgs/22.05";
outputs = { self, nixpkgs, nxc }:
let
mb2 = prev.callPackage ./MADbench2 { };
in {
defaultPackage.${system} =
self.packages.${system}."composition::nixos-test";
devShell.${system} = nxc.devShells.${system}.nxcShellFull;
