Inspect the composition.nix file
If you open the composition.nix file, you will find the following:
{ pkgs, ... }: {
roles = {
foo = { pkgs, ... }:
# add needed package
# environment.systemPackages = with pkgs; [ socat ];
testScript = ''
foo.succeed("true")
The composition is a function that takes a set as input ({ pkgs, ... }) and returns a set containing:
a
testScriptstring -
a
rolesset of NixOS configurations
What interest us for the moment is the roles set.
In the example above, we define a single role named foo with an empty configuration.
We can add packages to the environment by uncommenting the environment.systemPackages line:
{ pkgs, ... }: {
roles = {
testScript = ''
foo.succeed("true")
