Add a PFS to the composition
For the moment the tests are only performed on the local file system of one computer.
Let us to setup a parallel filesystem to evaluate its performances. For this tutorial, it will be GlusterFS.
The approach will be the following:
add a new role
serverto the composition -
setup the PFS server on the
serverrole -
mount the PFS export on the compute nodes
