Generalization of the composition
As you can see from the previous section, the scaling of the number of computing node is a bit cumbersome.
Fortunately, NixOS Compose provides the notion of role to tackle this issue.
A role is a configuration.
In our case, we actually have only two roles: the NFS server and the compute nodes.
The configuration of the compute nodes is the same no matter how many compute nodes.
Thus having to define the configuration for node1 and node2 is redundant.
roles = {
node = { pkgs, ... }:
# add needed package
environment.systemPackages = with pkgs; [ openmpi ior glusterfs ];
# Disable the firewall
networking.firewall.enable = false;
# Mount the PFS
fileSystems."/data" = {
device = "server:/gv0";
fsType = "glusterfs";
server = { pkgs, ... }:
Building
nxc build -f g5k-nfs-store
Deploying
Reserving the resources
export $(oarsub --project lab-2025-compas-nxc -l nodes=3,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
Starting the nodes
The nxc start command can take an additional yaml file as input describing the number of machines per role, as well as their hostnames.
The following yaml file will create 3 machines: server (one instance per default), two node instances (node1 and node2).
# nodes.yaml
node: 2
You can deploy the composition by passing this yaml file to the nxc start command:
nxc start -m OAR.$OAR_JOB_ID.stdout -W nodes.yaml
Connect to the nodes
nxc connect
Remount the volume (to run once on any of the nodes):
cat /etc/hosts | grep node | cut -f2 -d" " | xargs -t -I{} systemctl --host root@{} restart data.mount
Release the nodes
oardel $OAR_JOB_ID
