Packaging the MADbench2 benchmark
TODO: create a repo with a make make install setup for MB2
Nix Expression
{ stdenv, openmpi }:
stdenv.mkDerivation {
name = "MADbench2";
src = ./.;
buildInputs = [ openmpi ];
installPhase = ''
mkdir -p $out/bin
mpicc -D SYSTEM -D COLUMBIA -D IO -o MADbench2.x MADbench2.c -lm
mv MADbench2.x $out/bin
Questions:
- do we make them add to a flake this and import it later?
Try to run the benchmark locally
First, enter a nix shell with the packaged MADbench2 and openmpi.
nix shell .#MADbench2 nixpkgs#openmpi
Once in the shell, you can run the benchmark with:
mpirun -np 4 MADbench2.x 640 8 1 8 8 1 1
It should output the following:
MADbench 2.0 IO-mode
no_pe = 4 no_pix = 640 no_bin = 8 no_gang = 1 sblocksize = 8 fblocksize = 8 r_mod = 1 w_mod = 1
IOMETHOD = POSIX IOMODE = SYNC FILETYPE = UNIQUE REMAP = CUSTOM
S_cc 0.00 [ 0.00: 0.00]
S_bw 0.00 [ 0.00: 0.00]
S_w 0.01 [ 0.01: 0.01]
S_total 0.01 [ 0.01: 0.01]
W_cc 0.00 [ 0.00: 0.00]
W_bw 0.12 [ 0.12: 0.12]
W_r 0.00 [ 0.00: 0.00]
W_w 0.00 [ 0.00: 0.00]
W_total 0.13 [ 0.13: 0.13]
C_cc 0.00 [ 0.00: 0.00]
C_bw 0.00 [ 0.00: 0.00]
C_r 0.00 [ 0.00: 0.00]
C_total 0.00 [ 0.00: 0.00]
dC[0] = 0.00000e+00
What interest us in this tutorial is the total time spent writing: W_total.
