Deploying the g5k-nfs-store flavour
Reserve the nodes
Let us reserve 1 machine for an hour on Grid'5000:
export $(oarsub --project lab-2025-compas-nxc -l nodes=1,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
You can use oarstat -u to check the status of the reservation
List the reserved machines
NixOS-Compose needs a list of target machines where to deploy the software environments. This list will be written to the file OAR.$OAR_JOB_ID.stdout in the current directory once the machines are available.
cat OAR.$OAR_JOB_ID.stdout
Which should output something like
dahu-2.grenoble.grid5000.fr
If the file does not exist yet, your reservation might not be ready yet. You can check with oarstat -u, looking for the "S" column. "W" means waiting and "R" means ready. In any case, the next command will wait for the creation of this file.
Deploy
nxc start -m OAR.$OAR_JOB_ID.stdout -W
Release the node
oardel $OAR_JOB_ID
