Adding a configuration file
IOR allows to take a configuration file as input. In this section we will integrate this configuration file into the configuration.
A IOR configuration file looks something like this:
IOR START
api=POSIX
testFile=testFile
hintsFileName=hintsFile
multiFile=0
interTestDelay=5
readFile=1
writeFile=1
filePerProc=0
checkWrite=0
checkRead=0
keepFile=1
quitOnError=0
outlierThreshold=0
setAlignment=1
singleXferAttempt=0
individualDataSets=0
verbose=0
collective=0
preallocate=0
useFileView=0
keepFileWithError=0
setTimeStampSignature=0
useSharedFilePointer=0
useStridedDatatype=0
uniqueDir=0
fsync=0
storeFileOffset=0
maxTimeDuration=60
deadlineForStonewalling=0
useExistingTestFile=0
useO_DIRECT=0
showHints=0
repetitions=3
numTasks=16
segmentCount=16
blockSize=4k
transferSize=1k
summaryFile=/tmp/results_ior.json
summaryFormat=JSON
RUN
IOR STOP
It gathers the information about the experiment.
It can then be run as:
ior -f <IOR_CONFIG_FILE>
We will put this configuration file in the composition in order to make the experiment reproducible.
Let us store this file locally in the file script.ior.
We can then create a file in /etc/ that will point to the content of the file in the nix store.
In the following configuration we will write the file at /etc/ior_script:
node = { pkgs, ... }: {
networking.firewall.enable = false;
environment.systemPackages = with pkgs; [ openmpi ior glusterfs ];
environment.etc = {
ior_script = {
text = builtins.readFile ./script.ior;
# Mount the PFS
fileSystems."/data" = {
device = "server:/gv0";
fsType = "glusterfs";
Building
nxc build -f g5k-nfs-store
Deploying
Reserving the resources
export $(oarsub --project lab-2025-compas-nxc -l nodes=2,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
Starting the nodes
nxc start -m OAR.$OAR_JOB_ID.stdout -W
Connecting
nxc connect
Running the benchmark with the script
Remount the volume (to run once on any of the nodes):
cat /etc/hosts | grep node | cut -f2 -d" " | xargs -t -I{} systemctl --host root@{} restart data.mount
From the node:
cd /data
ior -f /etc/ior_script
Release the nodes
oardel $OAR_JOB_ID
