Setting up the GlusterFS server
To set up the GlusterFS server, we need to configure several things:
open ports for the clients to connect: we will actually disable the entire firewall for simplicity stakes, but we could be more precise in the ports we open
Enable the
systemdservice for the GlusterFS server -
Define the export point
server = { pkgs, ... }: {
# Disable the firewall
networking.firewall.enable = false;
# Enable the glusterfs server services
services.glusterfs.enable = true;
# Define a partition at /srv that will host the blocks
fileSystems = {
"/srv" = {
device = "/dev/disk/by-partlabel/KDPL_TMP_disk0";
fsType = "ext4";
# we also add the htop package for light monitoring
environment.systemPackages = with pkgs; [ htop ];
Note that the KDPL_TMP_disk0 label is only valid on Grid'5000.
