Run the benchmark in the environment
As done previously, we have to go through the nxc build and nxc start phases.
Building
nxc build -f g5k-nfs-store
Getting the node
export $(oarsub --project lab-2025-compas-nxc -l nodes=1,walltime=1:0:0 "$(nxc helper g5k_script) 1h" | grep OAR_JOB_ID)
Deploying
nxc start -m OAR.$OAR_JOB_ID.stdout -W
Running the benchmark
Once the environment is deployed, we connect with nxc connect.
We can now run the benchmark.
ior
The output should look something like that:
[root@foo:~]# ior
IOR-3.3.0: MPI Coordinated Test of Parallel I/O
Began : Tue Sep 13 14:08:28 2022
Command line : ior
Machine : Linux foo
TestID : 0
StartTime : Tue Sep 13 14:08:28 2022
Path : /root
FS : 1.9 GiB Used FS: 1.3% Inodes: 0.5 Mi Used Inodes: 0.1%
Options:
api : POSIX
apiVersion :
test filename : testFile
access : single-shared-file
type : independent
segments : 1
ordering in a file : sequential
ordering inter file : no tasks offsets
nodes : 1
tasks : 1
clients per node : 1
repetitions : 1
xfersize : 262144 bytes
blocksize : 1 MiB
aggregate filesize : 1 MiB
Results:
access bw(MiB/s) IOPS Latency(s) block(KiB) xfer(KiB) open(s) wr/rd(s) close(s) total(s) iter
write 3117.60 13205 0.000076 1024.00 256.00 0.000014 0.000303 0.000004 0.000321 0
read 3459.03 15107 0.000066 1024.00 256.00 0.000022 0.000265 0.000002 0.000289 0
remove - - - - - - - - 0.000121 0
Max Write: 3117.60 MiB/sec (3269.04 MB/sec)
Max Read: 3459.03 MiB/sec (3627.06 MB/sec)
Summary of all tests:
Operation Max(MiB) Min(MiB) Mean(MiB) StdDev Max(OPs) Min(OPs) Mean(OPs) StdDev Mean(s) Stonewall(s) Stonewall(MiB) Test# #Tasks tPN reps fPP reord reordoff reordrand seed segcnt blksiz xsize aggs(MiB) API RefNum
write 3117.60 3117.60 3117.60 0.00 12470.38 12470.38 12470.38 0.00 0.00032 NA NA 0 1 1 1 0 0 1 0 0 1 1048576 262144 1.0 POSIX 0
read 3459.03 3459.03 3459.03 0.00 13836.14 13836.14 13836.14 0.00 0.00029 NA NA 0 1 1 1 0 0 1 0 0 1 1048576 262144 1.0 POSIX 0
Finished : Tue Sep 13 14:08:28 2022
If the previous command fails, it might be because of the network interface of the Grid'5000 node you deployed on.
You can try to run the ior command in a more explict way:
[root@foo:~]# mpirun --mca pml ^ucx --mca mtl ^psm2,ofi --mca btl ^ofi,openib --allow-run-as-root -np 4 ior
Release the booking
Now we are done, we exit the connection to the node and release this reservation.
oardel $OAR_JOB_ID
