Installing NixOS Compose
The python API
We can install NixOS Compose via pip:
pip install nixos-compose
You might need to modify your $PATH:
echo "export PATH=$PATH:~/.local/bin" >> ~/.bash_profile
source ~/.bash_profile
The nix package manager
NixOS-Compose unsurprisingly needs Nix. Let us install it locally:
nxc helper install-nix
This will put the nix store in ~/.local/share
Set up a preloaded store
To accelerate a bit the tutorial, we will preload the store to avoid having to download a lot of packages:
curl -sL https://gitlab.inria.fr/nixos-compose/tuto-nxc/-/raw/main/misc/import-base-store.sh | bash
